front and rear diff lube and t-case
Discussion in 'The Garage' started by Justin Fleming, Sep 7, 2005.
  1. Justin Fleming
    Justin Fleming 1/2 ton status Premium Member
    Aug 24, 2005
    765
    4
    Oxford MI
    I have an 86k5 blazer from what I read
    80/90 gear lube for the front and rear diff
    t-fluid for the transfer case
    Is t-fluid for the transfer case correct???? I have some 85 quaker state gear lube that I was wondering if i could use that to top off the diffs??
    thanks
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    if you have the np208 t-case atf is the correct lube. I run 85w-140 in my diff's, but thats mainly cause both are a little leaky, and it leaks slower with thicker oil.
  3. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    that's what my 87 takes. tranny fluid.
