Front assories
Discussion in 'The Garage' started by 1979jimmy350, May 28, 2004.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    Will the front assories from a 4.3 V6 fit a 350. I am looking to use all of the front assories from a 4.3 to convert my 350 to serptene drive insted of the old v-belts.
    Will this work?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I believe the answer is yes and no. Depending on the year of your engine it could work. The later engines have more holes in the end of the heads that I am pretty sure the serp brackets bolt too, if your engine has the proper holes then yes it will work. The front of the 4.3 V/6 and the front of V/8's are the same with the only difference being the year split.
  3. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    what years were the changes made to the heads
  4. dyeager535
    26,980
    This isn't going to help much, but I've got '96 heads on my truck now, (350) with 1987 accessories bolted up. I also had 1974 brackets bolted up to the Vortecs, they worked fine.
    The 4.3 is essentially a 350 minus two cylinders, there should be no major differences between them in accessory mounting. Perhaps on the new new 4.3's, but I suspect since their inception to at least '96, and probably later, the face of the 4.3 is the same as any other Gen1 (think thats right) small block.
    FWIW, I used the drivers side PS pump bracket spacer from a 4.3 truck to bolt my PS pump up in my truck with headers. Perfect fit! /forums/images/graemlins/smile.gif
    I'm only posting because no one with more 4.3 experience has spoken up, hopefully you'll get a more definitive answer.
