front auburn, eaton or something else?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5DRAGER, Sep 25, 2001.
  1. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    Getting ready to change the front gears in my 10 bolt and am wanting to install some type of a limited slip. This truck is a daily driver with mild to moderate trail riding and of course for winter. Was wondering wich would be better an eaton, auburn, auburn pro, or something entirely different. Thanks
  2. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I say if you are going to spend the money, look at the ARB!! I had an Auburn, I hated it, it was worthless to me...the ARB is the best of both worlds in my opinion...
    Just my .02
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Eaton all the way, but not the gov-lock, the newer one with the carbon fiber clutch material !
    FYI Auburn Gear L/S will wear out, and it is not rebuilable, this is a know fact not opinion !
    Good luck
  4. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I have Auburn Pro Front and rear ......it will wear out, as will any cluth type LS.....the Eatons are rebuildable, and can be had with an optional 800lb spring....someone in here got theirs from Randy's I believe......I went with Auburn because of the moderate off roading I do, and because I roadtrip this truck fairly often ....it has probably the tightest torque bias available, and it's half the price of an ARB.....I don't need lockers or 6" lift or 38's for what I do.....I have Moly shafts in my 10B/12B and I run 33's (AT on 8" street/MT on 10" for play}.....mostly Black Dirt Mud in Texas......I have yet to find a mud situation which will overcome the bias in either Auburn......as much as I like my setup, I'd opt for the Eaton with the bigger springs since it's rebuildable.....I think that most clutch types have a tighter bias than the gear type LS.....any LS is more forgiving to your front end parts, so you don't break as easily as with a full locker.......they all work, you just need to decide how you are gonna use it most of the time......there is no wear on front with the hubs unlocked.....good luck.....JD
    Stuck?...Hell no..I still got some gas left..
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Go with a lock rite. I put a lock rite in the front of mine and love it. It works alot better than a limited slip.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I would go ARB so you have some control of when you are locked and unlocked. Otherwise even the posi's I assume would affect steering and drivability in the snow and street, but I have never had that setup. My Old F#rd had a Detriot up front it made winter absolutly misrabale till I found an axle to swap it with.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  7. Blazin Obsession
    Blazin Obsession Registered Member
    Sep 25, 2001
    64
    B.C Canada
    An ARB would be best if you have lots of dough, But I use an Eaton posi and think it is great, I would'nt wish a 10 bolt with a locker on my worst enemy. From personal experience I found that a 10 bolt + locker = broken axles and finally a cracked carrier. Get something that will release before things break.
  8. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    How is that eaton in the front? how is turning and driving on the road in 4wd? What spring are you running in it?
    -Mikey
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I would go with a Detroit TrueTrack. It is a torque sensing diff. Most LSD's wait till one tire slips and than limits that slip. The TrueTrack sends the most power to the wheel with the most traction so the tire with less traction will shouldn't slip in the first place. It is a copy of the Torsen that is used in the Hummer.
    From what I have heard they will be making a locking version like a ARB only it will be a LSD when not locked. That is what I will put in my front end when it comes out.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  10. kpanza
    Dec 8, 2000
    1,579
    I've had a 10 bolt + locker (ARB) in my front end for some time now, not one single problem. There is a gross misrepresentation of the 10 bolt on these boards - they don't break every five seconds like everyone says, at least not mine. I think it is mostly due to the way people drive, and I have expounded on this point innumerable times on here. For the ultimate in control, there is nothing quite like the ARB, with maybe the exception of the new OX Locker (but it is even MORE expensive than the ARB!) As you know, opinions are like *ssholes, everyone has one!
    You need to sit down and be honest with yourself about how you really plan on using the truck - that will then lead you to your answer!
    Just my .02
  11. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I have to back what Triaged says. Although I don't have first hand experience with the TruTrac, I do with the Torsen. This is "THEE" reason the HMMWV &amp; Hummers work so damn well: Torsens front and rear. I've driven HMMWVs with less than optimum snow tires (Wrangler MTs &amp; RTs) and have been impressed at all speeds. And you cannot feel it working (thru the wheel) up front, but it is! ARBs are nice but you usually don't use them cruising down the street when it turns slippery white.
    If they made a TruTrac for my Dana 60 (front) I'ld be buying one tomorrow.
    Real trucks don't have spark plugs!<P ID="edit"><FONT class="small">Edited by DieselDan on 09/26/01 05:47 PM.</FONT></P>
  12. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Thanks for the posts. The ARB and full time locker is out not spending that much for the moderate wheeling I do. Leaning towards the Eaton since its rebuidable, going to check into the heavier spring for it though. But the Detriot Trutrac sounds interesting. Anyone here actually using one. How does it work?Is it rebuildable?Does it have clutches or cones? Are any of these noisy when turning like a full locker?
  13. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    Tell me more about the Torsen? How is that in snow and crude in the winter. I would love to find something that would work in the snow and would make turning easy enough tor drive on tight trails and on the street... how is the turning w/ the front locked in?
    -Mikey
  14. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Check out http://www.4x4review.com/products/drive_train/truetrac.asp
  15. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    no warrantee on a true trac with tires over 33"
    'humvee' and 'works well' in the same sentence, weird
  16. cool write up. the true trac sounds sweet for a front end application. especially in snow and ice.
    <font color=blue>"What does mine say?"
    "SWEET! What does mine say?"
    "DUDE!" </font color=blue>
  17. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Actually Torsen diffs are available for limited aftermarket applications through non-OEM sources. Check out <a target="_blank" href=http://www.reiderracing.com/diffs.htm>http://www.reiderracing.com/diffs.htm</a>.
    I put a Torsen in the rear of my S-Jimmy this summer. It is VERY smooth as well as silent in operation. Raise a tire in the air though and it won't spin the tire on the ground. [​IMG] But as long as there's some traction on each side, it keeps pulling you through.
  18. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
  19. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    Yes '77,
    "HMMWV works well" in one sentence. Better than them little Bombadier/VW/Fiats yours troops scoot around in, LOL. How many troops with gear can dismount that in a hurry? How do mount a .50 Cal on it and can you still return fire after it's "turned turtle" from the recoil? Just pokking ya, I love them little things, as long as I don't have to go to war in one.
  20. Overdrive
    Overdrive Registered Member
    Feb 28, 2000
    93
    Gilbert, Arizona
    HarryH3,
    Yea, the true track will do that as well, if one tire is off the ground. All you need to do is lightly apply the brake and it will lock. I put in a true track on my 77' k5 and it was great! (rear only)
