front axel identification
Discussion in 'The Garage' started by 69K5, Apr 15, 2003.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    Went junkyard shopping today and stumbled up on a dodge power wagon that i thought had a d60 but it said 44-8 where they usually say d 44. also found an 80 something gmc. it had a d60 i think. doesnt a d60 have the pasenger side spring perch as part of the gear housing and not seperated to the side on the tube. the dodge also had the same mounting place. both trucks were one ton. i know theres a chart but it didnt have what i needed.can somebody please clarify this for me? the guy said 250 for the gmc front end. is that good price?
    thanks
    nathan
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    if it had three u bolts,, 2 on the driver side, 1 on the passenger side, and then 2 studs coming out of the pumpkin on the passenger side, then its a d60 on the front of the pumpkin in the lower left part of the pumpkin it will say 60f....... The steering arm will be held on by 4 bolts instead of three like your d44. there are other identifying charecteristics, but this should be all you need. 250 is a hell of a deal for a Dana60 front, make sure there isnt anything Terminally wrong with it though,
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The spring pad is incorporated into the diff housing on all Dana 44s and 60s.
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    if the GM was a k30, its a D60
  5. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    silver84k5
    thanks for all the info. iw ant to say it was but i am gonna go back and check just to make sure. then i am gonna call the wife and beg.
    zakk
    the emblims were busted off. the guy said it was a 1 ton though.
    thanks for all the help
    nathan
