front axel nut size (d60)
Discussion in 'The Garage' started by 69K5, Mar 9, 2004.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    My friend has a old military dodge crew cab lwb. the front axel is a d60. what size is the nut on this thing. its way to big for anything that we have and a hammer and chisel wouldnt do it. Iirc its alltime 4wd. no hubs to turn just a big coverplate.
    thanks
    69k5
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What nut are you trying to remove with a chisel? The wheel bearing nuts?
    You need a special socket for those! Don't go at them with a chisel!
    I had to replace ONE of those nuts. It was $13 with my discount at my auto parts store for ONE!!!!!
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    yep thats it. when ever you take off the cover plate its the one that you have to remove to take the hub and all off.
    do you remember what size it is?
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    ttt
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    YOU NEED A SPECIAL 4WD HUB SOCKET TO REMOVE IT!!!!!!
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    uh huh what he said...
    i have one for my 14 bolt and d44 front...
    but now I need one for my new d60 front.. /forums/images/graemlins/bow.gif
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Is there a way so that the 14B and D60 can use the same friggin $20 socket? I have nuts on my 60 and the 6-point slot things on the 14B.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    In my case this wasn't possible.
    Some sockets are a combo 4 prong and 6 prong, and I bought one.
    Unfortunately, the 4 prong part of that socket was too small for my '60 so I took it back and had to order the correct one.
    For me, it was part number (STL) 29000 for the 4 prong socket I needed, which is bigger than the 1/2 and 3/4 ton one. I think it retails for about $20.
  9. 77ChevyK10
    77ChevyK10 1/2 ton status
    Feb 2, 2003
    317
    Laveen, AZ
    if you get an extra set of 14B nuts and put them on the D60.
    I have read that the 14B, D60, D70, and D80 all use the same nut size just different amount of slots. But i've not yet made it 100% true yet.
    Andrew
  10. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    My D60 was originally equipped with a six slot nut instead of the four. I will check to see if those nuts fit in my 14FF socket and let you know. The only thing I won't be able to check is threads, but it will tell if the 14FF socket will fit the old D60 style nuts.
  11. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    You use what i'd like to call a bigass screw driver and a hammer.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    NO YOU DON'T!!!!!
  13. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    So I have found the 60 came with too many nut options. I have 6 pt regular style nuts, my dad's 60 has a 6 slot nut, and I saw one that had a 4 slot nut. Go figure /forums/images/graemlins/dunno.gif. I am gonna check the PN# on them and see if any match. I have seen the 14FF with standard style 6 pt nuts also. /forums/images/graemlins/thinking.gif
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Mine has four slot nuts that happen to be bigger than your usual 4 slot nuts. Boy was that irritating!! /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  15. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    You can rent the set of sockets from Oreilly for $100, you get it back once you return the sockets or you can buy the socket for $20-$30 /forums/images/graemlins/waytogo.gif
  16. Leadfoot
    Nov 28, 2000
    3,112
    I verified last night that the hub socket for the 14FF WILL fit the six notch style D60 nuts. I actually bought new 4 notch nuts for my D60 but thinking about using the original 6 notch style as I would only need one socket for repairs.... /forums/images/graemlins/thinking.gif
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    So, will 14ff nuts fit on a '60? I wouldn't mind having the same ones front and rear myself.
