front axle forward
Discussion in 'The Garage' started by rubbinz raczn, Dec 23, 2004.
  1. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    i know the 52" front spring swap relocates the front axle forward. 2 inches? if i used a zero rate as well to further move front axle forward would that cause any problems? crossover steering by the way thanks!
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Not speaking from personal experience but sapper just did it and ended up pulling off the zero rates due to pinion angle, it being 3 or so inches forward and had problems with his crossover on his 60.
  3. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    I drilled the spring perches and plates to move the axle forword another inch, no problems..
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah I believe you need to get the tapered 0-rates to keep the pinion angle good.:xmas:
