Front axle gear change question
Discussion in 'The Garage' started by Mr.Selfdestruct, Feb 9, 2006.
  1. Mr.Selfdestruct
    Mr.Selfdestruct Registered Member
    Jun 16, 2005
    14
    Tulsa, Ok
    Well, i've already gotten the 4:56 gears for the rear of my suburban installed, but i've yet to get the gears for the front differential.
    I had completely forgotten to ask the guy at the Differential shop, if there was a difference in the 4:56 gears in the rear compared to the front. Do i have to get a special reverse cut Ring and Pinion for the front differential? Or do i just use any 4:56 ring and pinion? Does the transfercase change the direction of the front driveshaft ?
    The truck has a 10 bolt corporate front diff.
    -Tim
  2. Mr.Selfdestruct
    Jun 16, 2005
    14
    Tulsa, Ok
  3. goldwing2000
    goldwing2000 Guest
    A 10-bolt is a 10-bolt is a 10-bolt (as long as it'a a full size).
    The only thing that changes is the axle spline counts and that doesn't matter to you.
  4. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Your good :waytogo:
