Front axle help
Discussion in 'The Garage' started by angler3211, Mar 1, 2007.
  1. angler3211
    angler3211 Newbie
    Mar 1, 2007
    North Carolina
    82 K5 Full time 4wd. Front hub cover leaking, leaving some droplets on outside of wheel. Resembles oil? Tightened hub cover torx bolts,wiped it off drove it for an hour thought that solved it. I drove it a couple days later more droplets on rim and just on left front.
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Some more punctuation and information please.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    You cannot tighten the cover on a full time 4wd they snap in place. You have auto hubs and I am assuming you are leaking something from the hub onto your tire? There is only grease in there so I would take the hub off and run a bead of rtv around the hub and around each screw to seal it up.
    If that is not the drops you are talking about then maybe a dog peed on your tires:dunno: :D
    Ira
