front axle id??
Discussion in 'The Garage' started by osbornl1, Nov 1, 2004.
  1. osbornl1
    osbornl1 Registered Member
    Oct 12, 2004
    14
    bought the blazer with these in it. rear is a 14 bolt for sure dont know if its ff or sf. it does have the 6 bolt flange style hubs on it(if that helps) also my biggest concern is the front axle its 8 lug has 2 ubolts on the passenger side and has chrome caps where lock outs would be. what i really would like to know is a part number for some milemaker lock outs. i am at a loss to what it could be i tried several different part numbers and that isnt it. please help
    Larry
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If it has flanges, It might not have the groove for the snap ring that holds the hubs in, you'll have to investigate.
    Does your front axle have balljoints or kingpins? What about your steering arm, now many bolts?
    It sounds like you have a D60 front. /forums/images/graemlins/thumb.gif
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    If the rear is a 14 bolt 6 lug it would most likely be a SF.
    The front would be a D44 or a 10 bolt. The D44 cover is flat on the right side (when viewed from the front) and the 10 bolt is circular. Lock out hubs will be no good if you have a NP203 transfer case. You will need to convert it to part time or replace it with a part time case.
    Edit: on the rear - if the axles bolt into the hub it would be a FF.
  4. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    2 u-bolts on the pass side point to either a D44 or a GM 10 bolt, the chrome caps would indicate a bearing hub that accepts an internal style locking hub.
    Later D44's and 10 bolts bolt axles both use the same locking hub so you should be okay buying locking hubs for an internal spline application (ie; any 1/2 or 3/4 ton 77+). /forums/images/graemlins/thumb.gif
  5. osbornl1
    Oct 12, 2004
    14
    the 14 bolt is an 8 lug but the hub that sticks out of the center of the wheel has 6 bolts on it.
    also i know this sounds lazy but does anyone have a part number for the correct style lock outs.
    i also already have a part time kit for the np 203 just need lock outs and i will have my saturday planned out.
    Larry
  6. divorced
    Jul 20, 2004
    5,115
