Front axle locknuts on '04 Wrangler? Dana 30?
Discussion in 'The Garage' started by guido666, Nov 17, 2005.
  1. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    What kind of axle is on the front of an '04 Wrangler? Dana 30? Will a D44/10b locknut tool work to take the hubs off on that too? It's my mom's Jeep and somehow she managed to break a u-joint (totally stock!?!). Is there a different socket if not?
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The same tool will NOT work. The Wrangler has unitized hub bearings and therefore usually a regular hex-head style nut torqued really tight. I think it's usually around a 32 mm size *but I'm not sure exactly what size*.
  3. guido666
    Feb 16, 2005
    788
    Longmont, CO
    It's metric though? I have a 3/4" Drive Ratchet with lots of big American size sockets.
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    32mm, I think, is equivalent to 1 1/4" in SAE.
  5. merace19
    merace19 1/2 ton status
    Sep 19, 2003
    372
    Mobile, Alabama
    1 3/8 will work but be real tight. I know i just done it If only the u joint dont take the nut off. Just take the 3 bolts that hold the hub on and slide the shaft and all out. then on the work bench put new u joint in. Just remember about the dust hat under the hub. I forgot to put it back on then when i put it on i had it turned the wrong way. I takes me about 5 minutes to tear that front end apart now. Bolts are 13mm 12 point. Brake bolts are 1/2 standard.
  6. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Thanks, now I get to work on mom's Jeep in the snow. :doah:
