front axle moved forward W\ hi-steer
Discussion in 'OffRoad Design' started by T r a i l r i g, Dec 31, 2005.
  1. T r a i l r i g
    T r a i l r i g Registered Member
    Sep 20, 2005
    12
    swirling in the toiletbowl of michigan
    i have ord standard x over now and i want to go to hi-steer but i moved my front axle forward to clear my tires and i am trying to find a definte anwser before i order the arm and get stuck with it....i have a 4 inch lift
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Did you use a 0rate to move the axle?
  3. T r a i l r i g
    Sep 20, 2005
    12
    nope, drilled perches, plates, and shims
  4. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Mine works fine with my Dana 60 moved forward 1" and with 6" springs
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I was told by James Watson that 2" forward is the max w/ thier hi-steer/x-over. James said he runs 6" customs that are moved forward 2" and that it just clears. He did mention that he would recommend a good bumpstop to avoid a super deep stuff of the tire which might make them come into contact.
