FRONT AXLE QUESTION
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TB2Blazer, May 10, 2003.
  1. TB2Blazer
    TB2Blazer 1/2 ton status
    Apr 6, 2002
    166
    Cleveland, GA.
    I have a 85 K5 blazer and I was reading the tech article on this website that describes how to convert a six lug axle to an eight lug axle and was wondering if I could take the parts out of the front axle of a two wheel drive 3/4 ton 85 suburban and put them in my existing ten bolt that I have on to make it an eight lug.
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Two wheel drive front axle?? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/thumb.gif
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> 2wds have A-arm suspension in the front, the parts are entirely different. You'll need parts from a 4x4. </font>
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    nope,. two totally different design trucks, you need to ind a 70s and up 3/4 ton 4x4 and swap knuckles and all onto your front axle housing
    theres no front axle under a 2wd, thats your first major problem right there
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    On a different note...... will the caliper supports work? Or are they different too????
  6. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    i had a pre i believe 76 model 44 w/ the 8 lug when i did my swap. (could be wronge with that 76 thing)but anyway there is a cutoff year when things were different. i had the later year. while i did the swap i noticed spindles, calipers, bearing etc, etc were the same. i also noticed that the backing plates did look the same. the 44bp were a bit more beefy though. but same diameter and all. i wondered the same thing, can i use them? never tried it out but if you do let me know cause i got a buddy who is about to do the same swap.
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    They're different, too
