front axle to 8 lug questions.
Discussion in 'The Garage' started by unicknn, Mar 24, 2003.
  1. unicknn
    unicknn 1/2 ton status
    Jul 5, 2002
    138
    In San Diego now but Im from Texas
    What will I need to convert me stock front axle on my 87 K5 from 6 lug to 8 lug? How much will it cost?
    lmk
    Nick
  2. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    backing plates, rotors, hubs, and studs. if you go new you ar eprobably looking at 200 or so, if you go to a scrap yard or get parts from folks on here probably 50-100. and the swap if fairly painless
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    thats about it. I usually get 50.00 for the hubs, studs, and backing plates. no rotors. (most of the ones I get are junk anyways) you can get new rotors for about 35.00 each. I don't have any as of now, but keep your eye's on the for sale board. they come up now and then.
  4. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    here we go again..j/k
    I was in your position about 2 months ago, well I did the swap and cost me 200.00 in parts then 50.00 for 2 new rotors about another 75.00 in bearing, races, and seals also a good time to replace the u-joints and ball joints as well as break pads. I have alot of info from fellow members too so if you want it I can pm it to ya. /forums/images/graemlins/grin.gif
    What would I do if I would do it again?
    I would have bought a 8 lug 10 bolt to start with, this can easily be done for around $200.00-350.00 and you may find a gear ratio you need or want. The conversion isn't hard it just has alot of cost that come up and swapping an axel would have less down time. The only reason I would keep your stock housing is if you already sank money in gears and lockers or the like. /forums/images/graemlins/thumb.gif
  5. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I got me a front 8 lug with 4.10 for 180 dollars.
    Then had the shop rebuild it, that probably cost another couple hundred.
  6. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    i'm about to do this also and was wondering if the spindles can be reused and are the bearing and races the same?what about the calipers?
    thanks,
    Jerry
  7. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    no spindles? no knuckles? this is the next thing on my agenda
  8. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    they all forgot the new rims and if you go bigger on the rims, new tires...
  9. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Please check out http://coloradok5.com/forums/showflat.php?Cat=&Board=partsforsale&Number=696760&page=1&view=collapsed&sb=5&o=&fpart=1
    Price is for the whole lot of stuff, i can seperate
    I just rebuilt this entire front axle about 1500 miles ago. It has new ball joints, wheel bearings, rotors, calipers, pads, inner axle seals, u-joints.
    It also has warn premium hubs, 4.10's, and a eaton posi. I have lots of spare parts if interested. Axle would go very well with a 14-bolt rear!!!
    I'm only getting rid of it because i got a dana 60!
    Thanks - doug
  10. supersize75
    Sep 27, 2002
    2,638
    This is a great deal in my opinion, by the time you do all this to yours you could have just bought this one! /forums/images/graemlins/deal.gif
  11. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    well i have a 77 1 ton 14 bolt with 4.56 gears and a detroit.my front is a 6 lug 10 bolt with 4.56 gears open.my tires and rims are steel 8 lug rims and my tires are just some plain old 36-13 -16 tsl so since my front is new all the way through i am going to just buy the backing plates hubs and rotors.i read the article about swapping to 8 lug ,but that guy just baught new spindles it doesn't say whether or not they were needed.i have 4 sets of spindles and dont want to give $100 a piece for them if i dont have to.
    thanks,
    Jerry
  12. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Nope, you dont need new spindles. Just get a rotor/hub assembly for an '87 K2500 Suburban (3/4 ton). Usually the assemblies will come with the studs already pressed on. From there all you need is the backing plates and the lockouts. You can re-use the stock auto locking hubs if you want to, but who would want to do that? /forums/images/graemlins/grin.gif Getting new bearings is a good call too.
  13. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    replaced my bearings last week.my warn lockouts will work too right?where would one buy those backing plates at?i've got new calipers also will those work with the 3/4 ton stuff?
    thanks,
    Jerry
  14. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    ttt cause i want the answer to this question too.
