front axle u-joint replacement
Discussion in 'The Garage' started by tarheel, Apr 14, 2003.
  1. tarheel
    tarheel Registered Member
    Apr 11, 2003
    65
    GA
    anyone know where i could get some info on how to replace the u-joints on a D44. i've never done it, and it looks a little involved. /forums/images/graemlins/eek.gif
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i would recomend buying a chilton, haynes, or similar manual for your model vechicle. it is a well spent 20 bucks.
  3. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    It's easy.
    Follow what GMCLegacy said and get a Haynes or Chilton that covers your truck.
    They have pictures and everything!! /forums/images/graemlins/grin.gif
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Hey GMClegacy, your avatar holds the new record as the largest file size ever for a 80x80 picture. 409kb! /forums/images/graemlins/eek.gif If you want to get that down to 15kb or so I can give you a hand, just let me know. I run a T3 and it still took 5 seconds or so to load for me, it's probably wreaking havoc on the dialuppers' systems. </font>
  6. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    pick up yourself a 4 Prong wheel bearing nut socket, you cant replace them sunsofbitches if you cant get to em, and when you pull the rotor off, dont let the bearing fall out of the near side of it, and when you take the hub off, use dental tools to get the stupid inner hub clip out of the hub, and you will most likely have to beat the snot out of the spindle to get it off, i did, we used a peice of a 2x4 as a spacer for the 3lb slege hammer. good luck, yes buy a manual. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
