Front axle wider than rear?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by johnnieg, May 22, 2003.
  1. johnnieg
    johnnieg 1/2 ton status
    Nov 10, 2002
    130
    CSU, Ft. Collins, CO
    I look at my truck from the sidewalk and it looks like my front axle has a substantially wider track than the rear. Is it supposed to do that? /forums/images/graemlins/confused.gif it's all stock right now.
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Yes the front 10 bolt is wider than the rear ten bolt. I dont remember the exact measurements but someone will chime in with those. Its all perfectly normal /forums/images/graemlins/thumb.gif
  3. johnnieg
    Nov 10, 2002
    130
    Okay thanks!
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    back axle is a total of 3" narrower. 1.5 on both sides.
  5. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    wow.
  6. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    what about d60, 14FF ???
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    check out this place, they have spacers to widen the rear...
    Echobit
  8. JDELBLAZ
    JDELBLAZ 1/2 ton status
    140
    STAMFORD C.T
    that depends if tis all stock chevy or not. stock chevy one ton the front will still be wider than the rear . if you buy a 1 or 3/4 van 14ff it will mach the chevy d60 front .
    if you buy a dodge dana 60 it is 2 inches shorter than the chevy so it will be closer to the truck 14bolt ff only wider by 1 inch a 1/2 inch on each side. the set up im using is the dodge dana 60 to bring the front wheels inward to get on narrow trails with a truck 14ff to keep the track width closer and wont need to hunt down the longer axle for the van 14ff
  9. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Is there a problem with the front being wider /forums/images/graemlins/confused.gif
  10. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Best bet if and when you want to upgrade is get the Van width 14 its the same as the front width. makes it look better as well. Hope this helps
