front axle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DumontsK5, Nov 5, 2006.
  1. DumontsK5
    DumontsK5 Registered Member
    Jul 26, 2006
    59
    williamsburg, VA
    my front axle is making alot of noise i was wheeling and in a bad mud hole and heard a loud pop then my 4 wheel drive sliped out and i heard a a loud thud noise anytime i put her back in 4wheel drive tires still grab and drive shaft is good! i made it out but on the highway i could hear alot of noise in the front axle sounded like the hubs maybe? any guesses!?
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    There is a possibility it's the Ujoint caps peaking out and hitting the knuckle,happened to me until it poped out and the joint grenaded.
  3. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Could be several things. Try checking the u-joints, hubs, and even the axle shafts for breakage.
    -Harrison
  4. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    if the tires still grab, id check the tcase for noises too, if it "popped out of 4wd"...
  5. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    I would also lean to the t-case for the issue, you have a 208 (chain driven.) It could hide a problem more than a gear driven one would.
