front axle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pigpen, Jan 3, 2002.
  1. pigpen
    pigpen Newbie
    Dec 12, 2001
    3
    louisa v.a.
    the bearing on my pinion gear is shot anything special besides a press needed to fix this.
    pigpen
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Which bearing? The inner or the outer? You will need to replace the races when replacing the bearing. If it is the inner bearing, you may also have to re-setup the gears. If it is the outer, you shouldn't have to re-set them up, but you will have to remove the carrier to get the pinion out. You will need something powerful to deliver the 400 or so ft lbs of pressure required to crush the crush sleeve on re-installation (you will need a new crush sleeve).
    All this is assuming a 10-bolt. Do you know what caused it to fail? Is there a bigger issue you also need to consider?
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
