Front Axle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77K-5, Apr 3, 2000.
  1. 77K-5
    77K-5 Registered Member
    18
    Texas
    Which is better - A Dana 44 or GM Corp.10 bolt for the front axle of a 77 K-5. I have an opportunity to buy a dana 44 for a good price - but not sure how much I would gain. I am not sure about the gearing yet, but just wanted to know about the axle part of it.
    Thanks,
    BS
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    It seams that there are allot more parts available for the Dana44. More aftermarket mods too!! So I would go for the D44 over a 10bolt.
    Rock ON![​IMG] 72 K5 [​IMG]
  3. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    I have a ten bolt and there are some nice strengthening mods you can do to them. I haven't had any problems with mine.If I remember correctly the ten bolt hasa bigger ring gear to and splines than a Dana 44. I think
  4. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    If there is nothing wrong with your 10 bolt, it is definitely not worth any time or money to change to a Dana 44.
    CB
  5. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Bottom line is that they are basically the same. I would not spend any money to swap one for the other.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Here are some basic stats between the two:
    Dana 44 - 8.5" ring gear, 30 spline - 1.31" axle shafts, u-joint size is 297-x Spicer or equivalent (except for some earlier ones with the 260-x joint)
    10-bolt - 8.5" ring gear, 28 spline shafts (pre-'89 or so, '89-'91 or so had 30 spline - 1.31" shafts), 297-x u-joints.
    Basically, if you already have a 10-bolt you won't gain much by swapping to a 44, but if you are starting from scratch I would get a 44.
