front axleshaft removal?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coolhandluke, Aug 3, 2003.
  1. coolhandluke
    coolhandluke 1/2 ton status
    Oct 23, 2001
    116
    Dallas Texas
    I'm trying to get out the front drivers side axle shaft, to replace the u-joint on a 3/4 ton axle. I have everthing off, down to the outer-shaft, However, I can't seem to pull the shafts out through the knuckle, the u-joint keeps getting stuck. Do you have to remove the entire knuckle to get the shafts out? suggestions?
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    no the knuckle doesnt need to come off. Is it hanging up somewhere in the diff? or at the knuckle? It should just pull out through the knuckle.
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    You should not have to remove the knuckle to get the shaft out. Make sure the knuckle is positioned like it would be if the wheels were pointed directly forward. In other words, make sure the opening in the knuckle and the axle tube are concentric. The shaft should then pull out. The clearances are pretty tight so you have to make sure everything is lined up. /forums/images/graemlins/thumb.gif
    BTW....the front axle doesn't use C-clips. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    well i guess you got the spindle off eh? lol...the knuckle needs to be pointed as if you were driving straight, then the axle shaft will come out, might take a couple good tugs to break it out..
  5. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    We got it out. thanks guys.
