Front axleshaft u-joint "inspecting"? (10 bolt)
Discussion in 'The Garage' started by dyeager535, May 19, 2005.
  1. dyeager535
    26,975
    I try to make the post title informative, but I have no idea how I'd word this.
    Crawling under my truck the myriad times I have lately, I looked at one of the front axleshaft u-joints. I'm sure they are original, they look like they are part of the shaft.
    However, I noticed where one cap comes through the shaft, whatever is coating the shaft there (paint, plastic from the factory u-joints, rust?) is "cracked". Basically what it looks like is that the cap has started to move around just a tiny bit. It's not a crack in the metal or anything, but I'm curious if anyone else thinks this is an indication that the shafts need pulled and these joints need replaced?
  2. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    I would change "reading" to "inspecting". I thought this was going to be a sort of FYI post or something in which I was going to be doing a lot of "reading".
    I'm not sure I understand what you are desribing. Is is the "seal" that is at the bottom of the cap. If so, I would be worried about it because with no way to regrease them they may be, or may start to loose the grease.
  3. dyeager535
    26,975
    Changed. :)
    How to describe. On a driveshaft u-joint, you can see the caps when it's installed. (looking from the side, not peering at the cross of the joint) On the axleshaft joint, I guess there IS a seal/plug like piece on the *outside* as well, so you don't actually see the cap?
    In this case, I guess what I'm seeing "cracking" is that metal seal from the crud surrounding it. I think what you are thinking of is the rubber seal that seals the cross to the cap. Thats "inside" the assembly, this is outside. This is a piece (metal I believe) that covers the ends of the u-joint cap.
    Problem is, I'm not really sure how those things are setup. IIRC there is a metal seal pushed in over the outside of the hole in the yoke for the u-joint cap.
