Front Bar
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Steve_Chin, May 7, 2001.
  1. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I just finished mounting the front anti-sway bar to my Blazer. Huge difference in handling. It is much flatter and more responsive to steering input. It understeers a bit, so it needs a little bit of a rear bar to balance it out. I might be able to get by on an air pressure adjustment, but I'm not sure about how that'd affect wear.
    Anyhow, I used a stock front bar and spring anchor plates off of a '78 Blazer 4x4 and fabricated frame mounts (didn't like how the stock perches off of the later Blazer would have looked and worked). I'll try to borrow a digital camera and post pix to my web site later.
  2. Steve_Chin
    Mar 6, 2001
    1,126
    OK, I got the pictures taken and they're on my Blazer's page:
    <A target="_blank" HREF=http://www.geocities.com/MotorCity/Downs/1963/BlazerPix.html>http://www.geocities.com/MotorCity/Downs/1963/BlazerPix.html</A>
  3. 72GMCJIMMY
    72GMCJIMMY 1/2 ton status
    Mar 17, 2001
    142
    Looks good, nice job.
  4. 71RestoRod
    71RestoRod 1/2 ton status
    Mar 7, 2001
    178
    Evergreen, CO
    Steve,
    That’s a sweet bit of fabrication! I think it looks great… and well thought out. It’s got to make a huge difference in the handling. Well done! Will you be able to implement quick-disconnects too?
  5. JungleBoy
    JungleBoy 1/2 ton status
    Jan 31, 2001
    243
    Houston TX
    Steve
    Great execution! Is your bar solid or tubular? I have one from an 86 K2500 that appears to be solid, although I have heard that many of these bars were tubes with solid ends.
    Take care
    JB
  6. Steve_Chin
    Mar 6, 2001
    1,126
    Thanks, guys.
    I will be able to use QDs once I put lift on the Blazer. There just isn't room between the frame and the bar to accomodate QDs without lift. Even with lift, I think that if the bar is connected and the suspension compresses fully, I'm going to have a contact problem.
    The bar is solid. It's too heavy to be hollow. I don't know if GM would have gone to the trouble of using hollow stock when making the bar solid is cheaper to do...
