Front blocks... *sigh*
Discussion in 'The Garage' started by sled_dog, Feb 4, 2006.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    went to lowes for an angle finder so I can make my tranny crossmember and as soon as I pulled into the parking lot I spotted a really beat maroon K20. Well it had K15 badges but 14 bolt FF rear and D44 8 lug front. Anyway, I saw it had either 37 or 38 SSRs on it, then out of the corner of my eye I caught what looked like front blocks. I went and parked, walked over to make sure I wasn't just seeing degree shims. Sure enough, it had 4" front springs and 2" blocks under those. I took a picture on the cellphone(that you can't see cause its so cloudy), and went into the store. When I came back out I left the guy a note on his window. I hope it doesn't blow away.
    Some people just heard my head.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Some people will just never learn :doah:
  3. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,015
    848
    Pinckney, MI
    yeah there are a few people arround here that either have blocks on the front, or should be on the scary steering page
  4. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    You should have set the truck on fire and hit him in the head with a tack hammer......j/k... :p:
  5. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I'm guessing he won't understand the note.
    Eric M.
  6. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    When I bought my 84 1 ton parts truck it had 4'' blocks all the way around! I had to retorque all the u-bolts in the front cause they where so loose the axle would walk back and forth on the springs when you turned the wheel!!!!:eek1: When I pulled the axle both spring center pins where broken and the leaves all fell out on the ground! This truck was being driven as a "family" rig buy the P.O.'s wife for about two years before he pulled the motor out for his Jeep!!!:yikes:. Never,ever use front blocks! By the time you buy blocks and longer u-bolts your getting close to the price of cheap lift spring anyway, so even someone saying they are trying to "save" money is retarded BULL SH*T!
  7. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    I agree. The person that owns that truck probably has no clue whats under it :D.
  8. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    A guy in my autoshop class has an early 80's k10 pickup. And he bought it with a 1 or 2 inch blocks in front. I told him he better get them out of there quick. hes like, its only bad when turning, so i go slow. He also says that he is waiting till get can get enough lift for 40's and buy the tires. He currently got bald 35" xterrains. It scares me seeing him drive it.
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    if u put the note in the wipers, it wont go anywhere. poor guy, prolly bought it like that....not his fault haha
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    a couple years ago one of my old buddies called me over to see his truck that he finished, pulled in the driveway and i see these tall blocks under the front axle. they were home made blocks, 1/4" steel plate welded into a block i told him he was a moron for doing it and said they will fall out. then he told me that they probably won't because he used a centering pin threw the springs and the blocks to the axle. he ran it a few times in the mud then i offered to trade him my 6" front leaves for 4" leaves and blocks. he put them in the next couple days, sold the old 2" springs with the 4" block on them to someone, the first run he had, the front axle fell off in the mud hole. i just laughed my ass off "see told ya that centering pin wouldn't hold"
    i haven't seen hardly any trucks with front blocks around here driving down the road, just at mudbogs suprisingly.
  11. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Dangerous and illegal has always been my motto on them too.
    http://community.webshots.com/photo/28668497/1029942094033211152XkdthbIDio
    My '75 K5 originally had 2" aluminum lift blocks all the way around when I first got it. The front had horrid noises everytime it turned from the shifting of the blocks. When I swapped out front springs, the center pins were gone and the centering holes were all wore out. Had they been taller, they'd have shot out or broken up probably. As it was they were already cracking.
  12. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    any way you look at it the blocks suck eather on the front or rear. inless its short block on the back like a 2 inch but nothing much bigger
    LUKE
