Front Body Mounts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by walt88, Oct 26, 2000.
  1. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    I was in my 88 K5 (4" Lift 33's) and my bro was in his 150 4x4 HD. He went out of this ditch, i followed. As I came up and out the body was twisted and i heard some sever creaking. my bro gets out, says my frame is not connected to the body anymore. i tore both front body mounts. I was wondering if i should do a body lift. Do I need to do anything with the shift linkage with about a 1" or 2" body lift?
  2. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    I have a two inch body lift and had to extend the shifter linkage. The lift kit came with short section of rod to lengthen the linkage.
  3. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I blew out a core support doing the same thing. When I replace them I'm going to use some springs to let the frame drop away from the body if it needs to before it does any damage. I've seen it done on a few trucks and it works great.
    Joe
    RIT Mini-Baja http://www.rit.edu/~bajawww
    Team Mudnuts http://www.mudnuts.org
