Front brake line question
Discussion in 'The Garage' started by Topdown, Dec 9, 2004.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    ok... so my question is this... why doesnt anyone run a hard brake line down the front cross-member, drop a "soft" line to the axle, run hard lines along the axle and the "soft" lines to the actual brakes?
    It seems to me that we spend so much time and money on extended brake lines that it would be more cost effective to run your own hard lines. Not to mention that a hard line along the top of the axle would be "safer" and the line dropped from the middle of the front cross member would never catch on anything and since its rare that you droop both front tires at a time (jumping aside) you wouldnt need extra loops or inches of line.
    I am thinking I might give this theory a try on my project... just for sh*ts and giggles.
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    you mean like the Dodges....
  3. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Or 70s fords
  4. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    i dunno... maybe cause then you need to buy a new hardline and (atleast one) softline for every wheel? Seems relatively inexpensive to just buy 1 soft line per wheel. Guy over on pirate has DOT approved ones, the shorter-than-28" lines are under $90 a pair. By the time you buy the extra short lines, fittings and hardlines to re-route everything, you'd prolly be approaching that unless you were using free junk or something.
    j
  5. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    How long do you need them, I bought Napa lines which are for stock 88 and up 2 WD GM's and they are long enough for about 4 to 6 inches of lift. They are only like $30 for a pair, the part number at NAPA is 38872.
