Front Brake Lines
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by clarkekent, Jun 25, 2002.
  1. clarkekent
    clarkekent Registered Member
    Sep 26, 2000
    69
    NY
    Where's the best place to get extended brake lines for the front brakes for a '72? I'd prefer stainless braided, but they don't have to be.
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I used the front lines fron Pro comp that are listed for '73 up.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I used the ProComp 73-91 kit. The front lines worked fine (ie fittings the right size and 6" longer then stock). The rear line was only like 2" longer then stock and had smaller threads for the axle hard lines. That was no problem because I was replacing the hard lines and just used the right size for the new lines and used a piece of aluminum to space the axle end away from the diff some.
  4. JoshA
    JoshA 1/2 ton status
    Apr 9, 2001
    104
    slc,ut
    when I extended my brake lines I had them made at a local hose shop. "evco house of hose" to be specific. any shop that makes hydrolic (sp?) lines can make them up much cheaper than the kits. my brake lines are braided and custom length.
    the good thing is they are much cheaper, great quality, and can be made to any length you want. the only down side is that you have to tell them its not for automotive use. I found this out from the guy at the shop. he helped my with everything I needed then said, "these are for off-road use only, right" wink, wink /forums/images/icons/wink.gif . depending on who you talk to, you may have to tell them it is for a sand rail, forklift, go-cart, ect. to get them to make them for you. just take in your old line and they should have all of the fittings ect you need to make new brake lines.
    they have worked fine for me for years.
    -Josh
  5. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Check with:
    http://www.freyracing.com
    They're an Earl's distributor that deals with the race car crowd. Tell them the lengths you need and the fittings that need to be on the ends and they can make the lines up for you.
  6. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    I got SkyJacker hoses from a 4x4 shop. They had a few different lengths. $70 for the pair.
