Front brake lines?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Savage, Dec 15, 2002.
  1. Savage
    Savage Registered Member
    Oct 28, 2002
    28
    Grande Prairie, Alberta, Canada
    Howdy, looking for longer than stock brake lines for our Blazer... but I have had nothing but bad luck with the steel braided Pro-crap lines on my Jeep, does anyone know of another Chev application (maybe pick up or van) that came with longer lines than the stock Blazer lines? I would prefer to stick with factory or jobber rubber lines, for ease of availability... . Thanks for your thoughts & information. /forums/images/graemlins/k5.gif
  2. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    try these numbers:front-38872 and rear-4138068, i believe these are napa numbers, good luck /forums/images/graemlins/cool.gif
  3. blazen_md
    blazen_md 1/2 ton status
    Aug 20, 2001
    129
    MD
    I believe that superlift makes longer than stock oe rubber lines. Check them out if you need a part # let me know I should be able to dig one up.
  4. Grim-Reaper
    7,385
    Atlanta
    Some vehicles use this nice little line that just happens to have the right fittings to screw a stock line into and the other end will screw into the hard line. Using these I have a 28 inch DOT approved parts rear line. It will leave a 4 inch section of hard line in the middle but you can work around that. You may also have to do a little work with a file or a dremel where it goes tthrough the frame to make it fit right.
    The bendix part number is 88519
    http://www.advanceautoparts.com/
    Part 88519
  5. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I have Skyjacker extended front and rear brakelines on my 79 and have had good luck with them.
  6. Gary 86 K5
    Gary 86 K5 1/2 ton status
    Oct 7, 2002
    204
    Mentor, OH
    I used the Napa ones on mine and they worked fine /forums/images/graemlins/cool.gif
  7. Savage
    Oct 28, 2002
    28
    Thanks for the part #'s guys, will order in those lines from Nampa. Your help is appreciated! /forums/images/graemlins/cool.gif
    Savage /forums/images/graemlins/k5.gif
  8. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    i like my skyjackers. p# FBL29 but that's for a 3/4 ton
  9. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    If I put 1 ton axles in my 1/2 ton will I need new brake lines?
    Andy
  10. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    lines off a 10 bolt will bolt to a dana 60... I believe you will need a new rear line if you weer 10 bolt to go to a 14bolt /forums/images/graemlins/ignore.gif
  11. Langosta39
    Nov 8, 2002
    156
    Moscow, Idaho
    What kind of new line? Should I buy a rear line for a 1-ton? Does anyone know if NAPA has 4" lift lines for this application?
    andy
  12. fourwheelerjeff
    Nov 16, 2001
    3,419
    6
    the napa numbers above are longer than stock, napa does not list brake lines for lifted vehicles, through parts books and trial and error, these numbers are what a lot of people use for 4 inch lifts, the 10 bolt and 60 are the same size banjo bolt, on the rear i would suggest taking your old one in and comparing it with the new part number to make sure all the fittings are the same size
