Front brake rotors
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fireinthehole, Dec 13, 2002.
    On a front 10 bolt, is there a difference in size of the rotor from a 1/2 ton to 3/4 ton? Also is there a difference in the calipers? I would like to put the larger rotors and calipers on if so.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i think only the calipers are same 1/2 and 3/4 ton but thats it im pretty sure
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The calipers are the same, the rotor is slightly larger on the 3/4 ton. You are aware that the 3/4 tons are 8 lug only and the 1/2 tons are 6 lug only, right? </font color>
  3. yep, I already converted to 8 lugs a while back. Just wondering about upgrading the front brakes, thats all.
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> If you converted to 8 lug awhile ago, then you've already converted to 3/4 ton brakes. Am I missing something here? /forums/images/graemlins/confused.gif </font color>
  5. i didnt swap rotors, only had to change the hubs from 6-8 lugs. I just thought there might be a difference enough between the 1/2 ton and 3/4 ton rotors to make a difference.
