Front brake upgrade for 10 bolt
Discussion in 'The Garage' started by CR, Apr 25, 2004.
  1. CR
    CR Registered Member
    Mar 20, 2004
    51
    Any upgrade kits for 10 bolt front disks? Trying to get better stopping power.
  2. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Hmm. First make sure your current hardware is good. You should already have the bigger master cylinder (the bore on the older ones like mine is smaller)... check your rubber lines, replace the master/booster if they're suspect, bleed the hell out of it, etc.
    Depends on how you drive, I suppose, but my '74 (all stock brakes) will lock all four and skid if I slam the fat pedal. (Great way to make passengers s&&t themselves /forums/images/graemlins/smile.gif)
    Anyway, not to dissuade you, but make sure everything else is new and shiny 'fore you go upgrading.
    -- A
  3. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Either go up to 3/4T front discs, or look to the aftermarket such as wilwood.
  4. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    If you're using cheapo pads then they won't work as well as some of the higher quality pads. I always use the premium pads from Napa, I forget exactly what they're called but Napa only carries 3 different kinds and it's obviously the most expensive one at $30 per side.
  5. dremu
    Feb 27, 2000
    15,968
    461
    Oh yeah -- forgot the consumables. Make sure your rears are adjusted, drums are good, rotors are straight, and get good pads & shoes. The local parts place I use happens to carry the Bendix as the high-end. Semi-metallic is the only way to go; if you're using organic pads, look no further than a new set.
    -- A
  6. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    Stainless Steel Brakes makes an upgrade that includes new cast iron calipers with larger piston (80mm) and new slotted rotors. Cost was $575 from Summit.
    -Scott /forums/images/graemlins/usaflag.gif
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I believe Summit carries the AutoSpecialty cross-drilled rotors....I think they're 75 clams each....
