front clip removal steps & tips?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by tp85, May 1, 2003.
  1. tp85
    tp85 1/2 ton status Premium Member
    Mar 14, 2002
    130
    Maryland
    i've decided to bite the bullet, and pull the front clip off my 1st gen. i did some searches, but only found pieces of information on how to remove the front clip.
    anyone have any complete articles or details on this job?
    anything you can remember would be appreciated!
  2. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    Check the message boards over on 67-72chevytrucks.com. The Pickups will be the same as a blazer.
  3. 72beater
    72beater 1/2 ton status
    Oct 11, 2002
    224
    Nation\'s Capital
    basically mine went like this: bumper, inner grill, outer grill, cowl cover, hood, radiator and support assembly, then fenders. As one piece comes off you can see the next more clearly. It's a lot of pieces parts, so bag them and tag them. hope this helps,
    Ernest
  4. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    As I recall I had to take the fenders off before the radiator support and I would suggest removing the wiring harness first. This will give you a great chance to examine and repair it if nescesarry. Be for warned!! once you go this far the might as well can easily become overwelming.
  5. 72beater
    Oct 11, 2002
    224
    Nation\'s Capital
    ooops, yeah, i think that is right after all. i remember it was a lot of stuff piled up in my garage for a long time.
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    you can remove both grilles as 1 assembly. Yes the fenders need to come off before the radiator support, and the inner wheel wells before the fenders. Dont forget to mark where the hood is before you remove it.
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Or you can remove the whole front clip as one piece. Unbolt the front mounts by the radiator and the bolts to the cowl. Unhook the wiring plug on the firewall. Take the radiator hoses off. 3 people to lift the front clip off.
  8. tp85
    Mar 14, 2002
    130
    Maryland
    now this is actually what i had in mind or had hoped was possible. i have a bunch of guys coming over to the house next weekend, so this could be perfect.
    is it really this simple to remove the entire clip in one piece? what a great design from chevy.
  9. the cork
    the cork 1/2 ton status
    Apr 20, 2003
    128
    mid west,
    you might want to remember how many shims are used on each
    mounting bolt, then when you put it back together your
    body lines will be easier to adjust, if that is important
    or not,just my 10 cents , /forums/images/graemlins/thumb.gif
  10. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    PM 4x4high (scott) on how to do this.
  11. Anthony72K5
    Anthony72K5 Registered Member
    Mar 17, 2003
    20
    I got my inner wheel wells out before my fenders, so I guess this is a YMMV thing.
  12. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
