front clip swap issues
Discussion in 'The Garage' started by got_mud, Nov 30, 2004.
  1. got_mud
    got_mud 1/2 ton status
    May 9, 2003
    316
    Wichita, KS
    i am putting a clip off an 81 custom deluxe c10 on to my 75 burb frame with the 88 obs cab and can't get it to line up. when i had the clip off the burb on there it looked like i didn't even need to shim it. if i line up the new clip with the cab, the core support is 2.5 inches back and 1.25 inches up from where it should be to bolt up. any thoughts? i always thought the front clips from 73-87(91) were swappable.
    also- is it possible to have a 'dial-up killin' "here's my trimmed fender" post with pics of all of them in one spot? i want to trim mine so i can keep from cutting my rubbers and i want to compare trim styles. i think i like the way rene did his.
  2. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    Not sure why you're front clip doesn't line up. Maybe some difference between pick-up frames and 'Burb frames or something?
    As for the way I trimmed my fenders, I did them from the inside out. If you look at the inside of the fender when it's not on the truck you can see where the inner bolts up to it. I cut slightly below that line, lopped the fang off just below the core support and angled the rear part...then blended the whole thing using a flap disc.
    Once I had the first one done I traced and cut a template to do the other front. then I modified the template slightly and did my rear with the same arch and curve
    Rene
  3. got_mud
    May 9, 2003
    316
    Wichita, KS
    i can't see there being any difference in the clips. my old one lined up. the cab is still lined up and bolted to the frame. its like the new front clip is tweaked or something. may just need a new set of eyes on it to figure it out.
  4. sublmnl1990
    sublmnl1990 1/2 ton status
    Nov 8, 2004
    419
    Virginia Beach Va.
    I am not sure if you said you swapped out core supports or not but when the grill style switched over you need to get the core support that goes with the same year set. like I believe the 73 - 80 are the same and then 81 through 88 and the 89 -91 on subs and blazers are of their on kind. But I would swear to this. /forums/images/graemlins/burb.gif
  5. got_mud
    May 9, 2003
    316
    Wichita, KS
    the front end i bought off ebay was complete. i took the old hood, fenders and core off the truggy and went to put the new clip on complete less hood and with the fenders bolted up to the cab the core is too far off to even get the bolt through the bushing mount hole. i'm gonna give it a few more looks and then i'm selling the new stuff and sawzalling the old setup and puttin it back on.
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i may be seeing things but it almost looks like the cab is too far back o the frame. i almost looks like you have a bit of room between the engine and the cab. i know mine doesn't have that much room. maybe the front mount on the burb is back a little more than the other vechicles. /forums/images/graemlins/dunno.gif
  7. got_mud
    May 9, 2003
    316
    Wichita, KS
    nah. thats just trickery. i didn't have the booster mounted on the cab yet. i can't think that its different, like i said- the old front clip bolted up perfect. ima gonna have to say screw it on this. these fenders are too nice to hack up anyway.
