Front Corner Rebuild...What should I replace
Discussion in 'The Garage' started by goblazeinco, Jun 17, 2002.
  1. goblazeinco
    goblazeinco Registered Member
    Nov 9, 2001
    33
    Longmont,CO
    I am replacing my front ball joints and would like to know what else I need to replace while I am in there. This is my first time doing this on a four wheel drive. The axle is a Dana 44. I allready have the Moog ball joints and need to know what bearings, seals,ect.. to replace. Should I replace the axle u-joints at the same time even if they are in good shape? Any help would be appreciated.
  2. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I'm doing the same job friday. Ball joints, grease seals, axle joints and hopefully all else will be good.
    Jim
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    leave nuthing unchecked.bearings,races,hubs ,axles.if anything looks questionable while your in there replace it /forums/images/icons/laugh.gif
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Get the wheel hub seals and the seal kit #SBK-1. This kit is the little spindle bearing on the inside back, and the two rubber seals for the stub axle shaft, and also the plastic washer for the stub shaft.
  5. goblazeinco
    Nov 9, 2001
    33
    Longmont,CO
    Thanks for the help guys. Any other comments would be appreciated.
