Front Corp. 10 bolt with Spicer axles? Am I nuts?
Discussion in 'The Garage' started by johnnieg, Apr 19, 2004.
  1. johnnieg
    johnnieg 1/2 ton status
    Nov 10, 2002
    130
    CSU, Ft. Collins, CO
    I was crawling under my truck and happen to look at the steering U-joints which were tunred just right to see "SPICER" on the axle side of both joints. Did 10 bolts use spicer axles or is this an aftermarket upgrade or replacement piece? If you need pics I can try later.
  2. johnnieg
    Nov 10, 2002
    130
    Re: Front Corp. 10 bolt with Spicer axles?
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif *ben stein voice* "anybody? anybody?"
  3. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I think the dana 44 and the 10 bolt use the same u-joints. So you probably have spicer u-joints in the front axles shafts.
  4. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    My rear shaft slip yoke end has spicer stamped on it?????
  5. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    The original axle shaft u joints were Spicer, at least all I have replaced.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep. As stated above, same size u joint.
