Front Crank Seal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tkjimmy, Feb 8, 2001.
  1. tkjimmy
    tkjimmy Registered Member
    Sep 21, 2000
    Washington State
    Does anyone know if you can replace the front crank seal without removing the timing cover? If the cover has to come off to do the job, do I have to drop the oil pan as well? I have oil blowing all over the front of my engine from oil flying off the harmonic balancer into the fan. I have never done this before, and any help would be great. Thanks............
    tkjimmy--Wa. State
  2. Blazer1970
    Blazer1970 1/2 ton status
    Old Mission, MI
    You should be able to do it, but it will be a little tricky to get the seal in there straight with the cover on the motor. If the balancer has a groove where the seal rides, buy the repair sleeve for it, or the new seal will leak too. You will need a puller for the balancer, and you should use an installer tool to put it back on.
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
