front cross member replacement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blizzybuilder, Jan 31, 2001.
  1. blizzybuilder
    blizzybuilder Registered Member
    Jan 24, 2001
    13
    Falmouth, MA
    In my 79 K5 the front cross member is snaped, is there any way I could replace it. And how would I go about doing it?
  2. KENBARBOUR
    KENBARBOUR Registered Member
    Jan 14, 2001
    54
    Mine is cracked, the one under the motor mounts. You can grind down the rivets and punch them through. Then find a good one from the boneyard and bolt it in with some grade 8 bolts. I'm hoping ORD makes a HD one to go along with their crossover steering kit.
    Is anybody else's cracked?
    Is this commen?
  3. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    mine is cracked too. i want to replace it. but i am worried if i remove it the frame might shift and i will have a hell of time lining it back up. i was told to weld a diamond shape to it. i have thought of making my own crossmember out of tubing rather than a regular one, it will hold up much better and be much stronger. anyone else have any input?
    Knife.
    knife.coloradok5.com
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Depdog did a review of his cross-over steering conversion and part of it required a new cross member. If I remember he had some shop drawings of the tube cross member he fabricated. It looked quite heavy duty. Only one problem, I can't remember where I saw the article [​IMG] It either on this site somewhere or on Off-Road.com
    Rene
  5. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Mine never cracked, but the bolts came loose all the time. I just did crossover and built a new one simular to Depdogs, but out of 2 X 2 X 1/4 tube instead of 1 X 2 like Dep. I also bent mine on a tubing bender rather than segementing it like Deps. I like the way it turned out. If I had a digital camera I woudl post a pick of it. I dont think that you can just get one out of the junk yard though. I had to cut my old one in half to get it out from between the frame rails. As far as line up it is not a problem. Just take a floor jack with a 2 X 4 and gently jack up the motor at the harmonic balancer to realign the holes. You can see the one Depdog made on the main page under project vehicles I believe.
    I thought I was wrong once,
    but I was mistaken
