Front CV Joint. How bad can it get?
Discussion in 'The Garage' started by primerk5, Mar 17, 2007.
  1. primerk5
    primerk5 1/2 ton status
    Jan 13, 2001
    220
    Finksburg MD
    How bad can a front CV driveshaft joint get before it is unusable. I know you can replace the u-joints in it but I'm talking about the Ball/pivot point. Or can you always rebuild them. The old guy at the driveshaft shop says that they can't be rebuilt.
    Luckily I have another shaft. The CV in it seems to be ok. I'm going to check the Joints, Re-grease it and install it.
  2. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    you can get a replacement ball for the CV from any driveline shop, I got mine from a local company called DTS. I can post the spicer part #'s later, when I get out of work.
  3. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    Yup, NAPA sells a rebuild kit that has the seal, ball, and spring. Last time I bought one it was around $25.00.
  4. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Yep, you can rebuild them. It's a bit trickey to press off the centering ball without a special tool.
