Front CV MAXED OUT??? Had it cut to length and....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Jun 29, 2002.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Is it possible to MAX teh CV in a front shaft? (YES!) I installed my front shaft after having it cut down to the correct length (26.5"), and when I installed it, the CV binds on itself when turning. DAMNIT! Just threw $65 into the breeze! /forums/images/icons/mad.gif /forums/images/icons/confused.gif
    What do I do now? Anyone?!!!
    -Dan
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    have u checked just to make sure that it isnt hittin the x-member. mayb some1 else can help u out that has had this trouble bfore
    NITRO
  3. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    cut all the stops off with your grinder ! thats what i did cuz mine bound also , but i dont have nearly as much lift as you tho its worth a try tho. if you needs pics i can get some sometime. - Andy
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Andy - I was spinning up the grinder inches from the CV with that thought in mind this afternoon! /forums/images/icons/smile.gif Just didn't have the balls! I was worried that removing material might make the shaft weak under my new crawl ratio and the torque of the 454! /forums/images/icons/shocked.gif /forums/images/icons/grin.gif I think I might shop it up.... its about time I experience some kind of carnage on the trails! SO FAR ***KNOCK ON WOOD*** I haven't broke yet.
    Anyone have thoughts on grinding out the stops in the CV? /forums/images/icons/tongue.gif
    -Dan
  5. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    well.. IT DONT WORK NOW DOES IT11!! /forums/images/icons/shocked.gif
    So go for it dude!!! just leave soem meat on it and grind the stops...
    Then when it breaks.. call jessie... /forums/images/icons/grin.gif
  6. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    i had to grind my stops down & then some, now it might hit the yoke end of the axle(just got my frontend re-geared so i haven't really 4x4 that much to tell yet if i need to grind the yoke but it looks close) running a 465/205 6" lift with ORD HD shackles on my k10
  7. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    STEPHEN told me to do this /forums/images/icons/wink.gif
  8. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Aaron- AGREED! That's what I was thinking in the first place, but I didn't want to render it worthless either!
    Josh- Ive got the SAME combo, but on a K5! 465/205 6"+1" w/ORD HD shackles. CV binds up pretty hard. I'm going to have to grind a good amount out to allow it to move properly, let alone allow the front axle to flex! /forums/images/icons/blush.gif
    Andy- Hell, if Steve said to do it, I'm going to the garage now! /forums/images/icons/wink.gif /forums/images/icons/grin.gif
    Thanks for the input from everyone! I'm off to go grind all the stops out of the CV... I'll post the results when I'm done.
    -Dan
  9. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    This might be late, but grinding the stops is what I did to mine. Been running the shaft for years and haven't run into any problems.
    Also did it for the rear CV.
    /forums/images/icons/laugh.gif
  10. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Good deal! I just took the grinder to the stops, and a few other edges that looked like they might cause problems... installed... and BADABING! Nothing rubs! So its all good! Thanks for the help guys!
    -Dan
  11. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    You will need to grind the tabs off on the CV to make it work. I had to on two different driveshafts! Take a pic for me and I will edit the image showing which ones to grind.
    Oops, just noticed you fixed it. But, did you check it by installing the shaft on the transfercase first, then spinning it around to check that you are getting enough droop when it cycles? Reason I am asking, you can have major failure when a CV binds.
  12. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Hey Krazie, if you installed your zero rates in the front make sure you RTI your truck. I did at Carlisle on our 25* ramp and found out with my 3/4" zero rates my draglink hit the spring.
  13. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I spent 1/2 hr. on the phone with ORD when I made the order for my Zero Rates. I actually brought that clearance subject up to them since my current setup occasionally has problems with interference between the passenger spring and the drag link!
    [image]http://community.webshots.com/photo/30767410/42376252wZHfyI[/image]
    After talking to them about a spacer for the steering arm... I decided not to relocate the front axle... just to save myself a headache...
    Thanx for the advise though Wayne! /forums/images/icons/wink.gif /forums/images/icons/grin.gif
    -Dan
  14. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    whew. hooray for this thread. To make a long story short, I had a 4" lift on my K20 and no problems with the front.. Now its on another K20, but with a th350/np205 instead of the th350/np203.. I used the original front shaft from the sm465/np205 truck, and there is no WAY its going to work! I guess because its shorter and therefor the angle is steeper. Pretty bogus, I thought I got lucky with that front driveshaft but I was wrong. I guess I can grind the CV but-- its just an inch or two too short (splines start to show on the slip yoke when extended) /forums/images/icons/frown.gif
    I cant beleive I have to grind this sucker on a 4" lift!! it might be more like 5" but still...
    oh well. glad to hear others have had this problem
    mike
  15. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    to correct the angles it is time to cut n turn the dif
    I have 10" springs and no cv issues, and no doubler to lengthen the shaft
  16. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    mj , i dont think it would be worth the work in the front to cut and turn it , besides most the other other guys dont have the equipment of the $ to do such a mod . Your suggetion would be best tho in the long run <maybe> .
