Front D44 locker
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cavalry, Sep 10, 2001.
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I found out my D44 carrier is junk yesterday. I figure now would be the time to swap in a better diff. I am leary about putting a detroit in the front as this truck is my plow truck in the winter. ARB is out of the budget. How about a lock right or whatever. I think for me a LSD in the front would be fine. Do front LSD's make the truck lose turning radius like a true locker?
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  2. Cavalry
    Oct 1, 2000
    978
    Anyone?
    Luke
    84 K5
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    You could try a True Trac(all gear LSD, no Clutches) since you are using it to Plow and are worried about turning radius. But for hard wheelin, they dont lock like a regular locker as much... Or possibly a Powr-Lok, they can be built(more clutches added and stiffer springs) to lock harder.. If you go with a Lock-Right, you will still have to buy another carrier.
    Mike
    <font color=green>"My K5 is purdyr than your sister!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  4. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Yeah Detroit tru trac is an extremley good posi /lsd. Wichever you prefer to call it.
    Doens't affect handling at all, great "manners" no lock/unlock weave, no chirping tires.
    Aurburn makes a good LSD. Duno if it affects handling but they say it will deliver more torque to the high traction wheel, even when the loose wheel traction is 0. and uses a hi-bias diff design.
    6in 87' K5 w/ 35" BFG muds.
    Kn filter
    What I need: 4.11 gears, Lim Slip Dif, Force2 Catback, 2"springs 4"flips,SSR's
