Front Dana 44 and Corp 10bolt. differences
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Lane, Mar 19, 2003.
  1. Lane
    Lane Registered Member
    Mar 19, 2003
    13
    Montevideo,MN USA
    I need a new ring pin and differential in my 79 gmc pick up and I know of a couple of blazers and a suberban that I migh swap with. The suberban has a dana 44 from looking at the cover. as long as the ratio is the same I am thinking of using it. I think the blazers have corp 10 bolt front axles.
    Are the diferentials/and or ring and pin interchangable between dana 44 and corp 10?
  2. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    If you want to exchange the entire housing then yes, they are interchangable.
    But the Ring & Pinions are NOT interchangable between 10 bolts and d44's.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Suburbans and Blazers have the same running gear in 1/2ton applications. 3/4 ton Suburbans are different.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    it wasnt the model of the truck that made it have either a 44 or a 10 bolt front it has more to do with year and drivetrain ordered/installed, in 77-79 years either 10 bolt or 44 could have been installed depending on year and drivetrain ordered, this goes for all trucks up to 1 ton
