front Dana 60 manual hubs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blacksmith, Nov 15, 2002.
  1. Blacksmith
    Blacksmith Registered Member
    Aug 25, 2002
    5
    Bavaria ( Germany ) town Bamberg
    Hello,
    i´m from germany and i recently purchased a 1979 chevrolet k5 with an open 10 and 12 bolt, 3.08 geared, 33 general tires, NP 203 TC, TH350, 350cui engine and a military M1009 blazer body sticking on the frame.
    The stock axles are worn. Bearings, king pin, seals and so on.
    I got an offer from a military surplus dealer for two 14bolt ff rear and two dana 60 front (4.56geared) ends for about 400§
    These axles come all incomplete. But i checked i can make out of these axles one complete rear and front unit (the rest are spare parts) with the exception of the missing manual locking hubs on the front dana´s.
    There are only the disc brakes mounted and the splined axle schaft is prodruding at the center of the disc.
    My question is now:
    When i buy Warn 1 ton manual hub´s, to complete the dana 60, will i get all the missing parts or is something else missing ???
    the one dana is a few yaers old but was never used. Zero miles !
  2. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    is everything from the bearing out missing from teh hub? New hubs should come with everything you need except maybe the lockrings
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> So long as you have the hubs that the rotors are pressed on to (the wheel bearings are in the hubs, then the rotor presses onto the hub with the wheel studs), then the hublock kit from warn should include everything else that you need. </font color>
  4. Blacksmith
    Aug 25, 2002
    5
    Yes, everyrthing from the bearing out is missing. The disc with bearings is on plance and from this point everything is missing
