Front Dana 60 parts
Discussion in 'Parts & Trucks Wanted' started by Ricktard84, Nov 20, 2001.
  1. Ricktard84
    Ricktard84 Registered Member
    Jun 25, 2001
    44
    TX
    Looking for the following:
    30spline outers for spares
    inner longside shaft
    35 spline lockright
    5.13 or 5.38 gears and numericly high/low ratio carrier less spiders
    spring plates to hold springs to axle
    yoke for pinion, must be new style(fine splined) 1350 prefererred, but 1310 ok.
  2. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    I have a 4.10 35 spline powerlock. I can also get the spacer plate so you can run ultra low gears. let me know if you are interested.
    IT'S A 1 TON THING.... IF I HAVE TO EXPLAIN IT, YOU WOULDN'T UNDERSTAND!!!
  3. Ricktard84
    Jun 25, 2001
    44
    TX
    Sorry, way to high gear ratio for me and Im using lockright in the front and spool in the rear D60. Thanks though
