Front Dana 60 rotors
Discussion in 'The Garage' started by mouse, Oct 11, 2006.
  1. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I will be going through the front axle in the next month and will re-do the brakes. I priced the rotor/hub assembles, and seen that the D60's are much higher priced than a D44 set up. Has anyone replaced just the rotors on these hubs? It looks like the rotors can be removed by separating them from the hubs by beating them off the wheel studs...
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    They come off like any Chevy 4wd front and 14FF rear. Remove the wheel studs and the rotor comes off:D. Line the new one up and drive the studs back in:D. I took mine to a shop and they turned them with the rotor still on the hub.
    Ira
