Front dana 60 studs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudddog91, Feb 4, 2002.
  1. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Hey does anyone know the diameter and thread pitch of the 2 bolts or studs which hold the leaf springs to the axle housing on the pass. side?
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think mine are 9/16 coarse in the housing and fine for the nuts.
    I just replaced the nuts.
    sorry cant be definate
    formerly 77chev
    still a jerk though
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    They are 5/8" and coarse thread. I just replaced some on a D60 when I installed a lift on another customers truck not too long ago. [​IMG] I used regular grade 8 bolts.
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  4. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    I believe Sir that you are correct! I just tapped mine last night in preperation for installation!
    '85 K5 : Run it til it breaks, then fix it and go again!
  5. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    I have to second what mj said. Mine are 9/16 dia fine thread. I've just used two old lug nuts for mine with the flat face against the spring plate.
    Brian
    89KBlazer
    Build it Right or Don't build it at all!!
  6. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    The two bolts that bolt the spring pad to the housing are 5/8 corse thread bolts. The studs that hold on the steering arm are 9/16 fine thread.
    Derf00
    1990 K5 Jimmy 350 Edelbrock Performer TBI, 6in BDS Lift, Dana 60, 4.56, Corp 14B Detriot, 16x10 AE 589's, 37x12.5 SSR
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    And, as far as I know, GM D60s all had bolts in the spring plates (well, 3 u-bolts, 2 bolts), not studs. Dodge had studs. Not sure about Ford.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked, 4" lift, 42" tires
    Some day: massive cutting, shorter wb and rear overhang.
