Front degree shims
Discussion in 'OffRoad Design' started by chvyhs, Dec 14, 2001.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I have a 1990 3/4T Suburban with your Heavy duty front shackles. I'm getting a set of old 6" lift springs, I was told they're about 5" now. How much of a shim do I need?
    <font color=red>Sure your Durango can go any place I can go, (if I hook a strap to it).</font color=red>
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    You'll have to put the springs in and then get an alignment to figure out if and how much shim you need.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You probably won't need a shim, put it together and check the castor, it should be about 6-8 degrees.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
