Front dif bump stop
Discussion in 'The Garage' started by sandawgk5, Jan 15, 2006.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Who here is still running their bumpstop for the pumpkin on the front dif. I am puttin in a 60 and want to remove it will I kill my oil pan if I dont have it? Will be running a 4" lift spring pretty stiff 5 leaf pack.
    Ira
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    neither of my 83s or my dads 85 came with one, they have the 2 over the spring plate and 1 on the pass side back side of the spring. ive never seen a bumpstop there in person, only in pics on here. i think you'll be safe.
  3. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I pulled mine. I had to though, because it was in the way of the headers. I also replaced the other two bumpstops with taller ones just in case.
  4. dyeager535
    26,982
    191
    I pulled the one off of mine and have been running it (with stock suspension) for years.
    My springs routinely contact the bumpstops on the frame (both the center and rear ones) and hasn't caused a problem.
  5. sandawgk5
    Oct 28, 2003
    6,881
    Great that is one more thing to take off before the front goes back in.
    Ira
  6. dyeager535
    26,982
    191
    Just as an FYI, I also picked up a couple of extra stock bumpstops to trim and see how much more flex I can get BEFORE I start having issues with the driveline.
    The stock stops have a lot of rubber to them before you get to the metal insert, I figure at least another half inch of travel to be had there, with enough rubber to still do the job. Odd to me in that the springs as is sit level (stock 3 leafs) but move so easily that they apparently "bottom out" all the time. I'm going to do a before/after to see if the issue is daily, or just off the road, but with the (typical) jarring ride of these trucks, I suspect even speedbumps are enough to bottom out. But that will be months at best. :(
