front diff and draiveshat noise
Discussion in 'The Garage' started by dheavychevy38, Sep 19, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    put a 8 inch lift on a 89 k5 and the front end kind of locks up or binds when you use 4 wheeldrive ????
    The other problem is a of the you joints are new and when you let off the gas there is a ching noise from the back any ideas?
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Check the front drive shaft for binding issues....
    Where at in IL????
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    You need to grind down the tabs on the CV joint of the front d-shaft. You'll see what I mean when you look at it. Put the t-case in N and unlock the hubs - you can turn the shaft freely then. You'll notice that when you turn it, there are tabs that now interfere with another part of the CV because of the increased angle of operation.
  4. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    it doesn't seem to but it is hard to tell i will check tomorrow
    i live in algonquin but have 40 acres in marengo
  5. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    i will check it tomorrow trying to get ideas thanks
  6. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Heck with a 4" lift, I am going to 'clearance my front D Shaft as was suggested by Heavy4x4....
    Marengo? As in almost Rockford?
  7. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    just to add everything worked great before i put the lift on the rear noise is what scares me
  8. TrailBlazinK5
    TrailBlazinK5 Registered Member
    Jan 13, 2003
    38
    Kansas
    Well i put a 4 inch lift on mine and probably having the same noise you are and i really have no idea cause it was just like yours didnt make the noise tell after the lift, and mine seems to only do it when im over 60mph and left off the gas, makes the noise for a few secs and then quits but doesnt do it every time....
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Probably front shaft rubbing the crossmember. Mine rubbed like crazy when I had an automatic. Oddly enough, it doesn't do it with the manual and its the same crossmember as before. Maybe the new tranny mount got me a little more clearance. Maybe I clearance ground the crossmember...I don't remember.
    I hardly ever drive on the road with my hubs locked anyway.
  10. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    ok front driveshaft taken care of nut i think my 205 is junk with pressure on it's ok but when you let off at like 30 or /forums/images/graemlins/k5.gifmore it sounds like gears not meshed right but only under free wheel
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I highly doubt there is anything wrong with your 205.
  12. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    strange, looking at mine aftefr the auto-manual swap, i don't even think my front shaft ill be able to fit at all, i think it's going to hit the xmember. yes, mine grinded real bad in 4x4.
