front diff. corporate 10 bolts specs needed
Discussion in 'The Garage' started by 1985K20, May 23, 2005.
  1. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    I'd like to know the torque specs for pinion nut + the turning torque for bearing pre-load on a 10 bolt corporate.
  2. 1985K20
    Jan 11, 2005
    191
    Quebec,Canada
    I forgot: does the 10 bolt pinion have a crush sleeve on it???
  3. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    Yes it does.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    GM 10 bolt 8.5" ring gear the pinion bearing preload is 20-25 in. lbs. for new bearings or 5-15 in. lbs. for used bearings. The 10 bolt does use a crush sleeve.
