Front Diff fluid color
Discussion in 'The Garage' started by Chrisblazzer89, Dec 25, 2006.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Hey guys is the front diff fluid color sopposed to be grey?
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    That just means it got contaminated. water and what not. Change it out and you should be fine.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Nope. It should be light brown.
    Now, is the fluid silver or cloudy grey?
  4. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    this is wat it looks like[​IMG]
  5. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    well i see the pic didnt work.
    Its sliver
  6. Can Can
    15,552
    136
    Silver? Does it look like silver metallic paint?
  7. 79k20350
    Nov 22, 2004
    7,757
    Ct
    That sounds like metal shaving in other fluids... Being its the front diff i doubght it though...If theres a limited slip (which would typically cause that color) its not too odd. It seems odd an open diff could make such a clor...
  8. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Attach the pic. Hit the button in the replys that looks like a postcard. then select the file.
  9. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
  10. Can Can
    15,552
    136
    That's not good. The silver you're seeing are flecks of steel, and it has to be coming from somewhere. Have you ever changed out the oil? Is there a chance it's still the original fluid?
    Regardless, swap in some new stuff pronto and keep an eye on it........
  11. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    still might be original
  12. Can Can
    15,552
    136
    Then there's a chance it could be leftovers from when the R&P was breaking in. Like I said, pull the cover, drain it, give everything in there a REALLY good clean up with some brake cleaner, and fill it up with fresh stuff. Then keep an eye on it.
    FWIW, Chris, every time I've bought a used vehicle, the first thing I've done is swapped out ALL of the fluids. If you don't know when yours were last done, I suggest you go about changing them all out sooner rather than later.
  13. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    CANMOREK5 do u know how many quarts i need to fill the front diff?
  14. Can Can
    15,552
    136
    I'm assuming you've got the factory 10 bolt front. If I recall correctly, the sucker takes a little more than 2 quarts. Don't quote me on that, though- it's been a while since I last serviced it.
  15. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    thanx alot wen the parts store open up tommrow i will but some more gearoil and watever else to replace the front diff fluid
    Wat do i need to replace the gasket? New gasket or silicone or both for my front 10b diff
  16. Can Can
    15,552
    136
  17. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    thanx for all the help im new to fully doing all this work myself i usualy have some friends help me but i want to be able to fix it all wen no ones around
  18. Can Can
    15,552
    136
    That's the whole point of CK5, brother. Passing on info and tech to the next generation will ensure the survival of our beloved K-series trucks........:thumb:
  19. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Yep thats y im makeing sure my son get a membership wen hes old enough to drive my/his 88 blazer. Hes only 1 1/2 years old :D :doah: :haha:but he love his/my truck
