front diff. gear swap with 36" tires?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rix_Gotta_Blazer, Jan 19, 2003.
  1. Rix_Gotta_Blazer
    Rix_Gotta_Blazer 1/2 ton status
    Dec 13, 2001
    104
    Hollister, CA
    front diff. gear swap with 36\" tires?
    i plan on puttin on some 36's eventually. i know you have to swap gears in the rear for anything bigger than a 35". but do you have to do any gear swapping in the front diff? thank for any input, Rick
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Re: front diff. gear swap with 36\" tires?
    The front and rear gears have to match. Otherwise you will bind up the T-Case.. I beleave they have to be within 2% Meaning if you have 4.10's in the rear. You can have 4.09's in the front. I know a company in Salinas that does great gear work...
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Your front and rear differential ratio must match otherwise your transfer case will bind and but when you run on anything with traction.
  4. Rix_Gotta_Blazer
    Dec 13, 2001
    104
    Hollister, CA
    i dont know crap-o-la about gears. good thing you told me about the t-case delima. it would be a while before this took place. but where is that shop in Salinas? my dad is looking for a shop to check out his Jeep and his 64' stang.
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    It is on Spence road.. It is a tractor repair place.. Pm me tomorrow to remind me and I'll get the name for you..
