front diff question
Discussion in 'OffRoad Design' started by BigBoy truck, Nov 14, 2001.
  1. BigBoy truck
    BigBoy truck Registered Member
    Oct 17, 2001
    47
    memphis tn
    I was wanting to know if there was any cons to putting a True Trac in my front diff i have manuel locking hubs so i figured that it would only be engaed when the hubs were locked but some guy on here said that some locjers make it hard to steer with them in the fron any ideas???
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    a true trac is not a true locker it is a gear posi- limited slip- so no clutches , you will be fine , but he is right if u put say a detroit locker "no spin" in it ....
    WHATS WRONG WITH A 305 ?
    81 K10 GOODYEAR 35" MTRS
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  3. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    I think the only problem you'll have is that it's not a real locker. But you can get a true-trac to really hook up if you just tap the brake a little when it's spinning.
    Otherwise, you shouldn't see any other drawbacks. You may notice some handling problems on slick roads (snow and ice) if you're getting a lot of wheelspin. Otherwise it'll be mostly invisible.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
