Front Drive line problems......suggestions?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by twenty_below0, Aug 11, 2002.
  1. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    I was Getting the new motor in and I noticed the shaft is really loose in the front where the slip yoke comes together, you can grab it and move it back and fourth 3/8"
    It's not the ujoints, just the splines.At normal height with 4" lift the shaft sit's about 1/2 way in. What is the cure for this, new shaft? THX
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    if the rest of the shaft and joints are good a machine shop can replace the slip yoke section of your old shaft, you might want to compare prices on a new shaft to having that one fixed to see which is the best way to go.
